Results 1 to 2 of 2
Thread: New Gears
    Aug 2017
    22
    New Gears
    I installed 3.91 gears into a 2011 Camaro.
    Do I update Ratio & Trans to the new gears or just Ratio?
    Do I need to change Ratio - Error?
    13,630
    Use the gear tire wizard under the edit tab.
    If using an automatic transmission you can have it auto scale the transmission changes for you.
