Results 1 to 7 of 7
Thread: Reading Fuel Composition
    Jul 2012
    Florida
    1,490
    2005 GTO, E40, Flex sensor
    My alcohol percentage used to work in my Channels. Now I cannot get it to read on either of the Alcohol selections. The Sensor that reads in Frequency works but I don't know what 118hz is equal to in percent. Is there some way to change frequency to percent? I have Alcohol percent shown in charts also and no numbers there.
    I found a chart that lists hz as a percent of alcohol, so I guess I will use that.
    2013 Silverado 5.3, 6L80k 8.8
    Sep 2007
    patton, pa
    160
    Did you try repolling for supported parameters and going back in to see if you could add the channels after that?
    Jul 2012
    Florida
    1,490
    No, I haven't. How do you repoll?
    Australia
    2,001
    scanner top left under "vehicle" should be in the middle bunch of options
    Sep 2007
    patton, pa
    160
    With the interface connected to the vehicle in the scanner go to the vehicle tab select repoll for supported parameters.. after it's done click on the add Channel gear.look under fuel system>composition
    Jul 2012
    Florida
    1,490
    Thanks! That did it. I don't know why sometime things change in the scanner. I made two drag runs last night and my tps read 37% when it was 100 and trans temp read 32 degrees.
    Sep 2007
    patton, pa
    160
    I lose channels all the time for some reason. And it really sucks if you go out and waste a bunch of time and gas logging and then don't have the chanels you needed working when you go to look at the data. I've made it a point to verify I'm logging everything I need every time I hook up
    2010 silverado 6.2 ,Doug Thorley try-y headers, cats deleted ,spectra air cold air, lifted with 33's,tsp vvt 1.2 cam hp tuners
