Results 1 to 5 of 5
Thread: Cant understand the numbers
    Jun 2016
    Fort myers, FL
    14
    Quick rundown 01 C5, stock except 1 3/4 headers, full 3 inch catless, vararam with maf moved closer to throttle body. I cant figure out why its running so rich?
    scan and tune posted, appreciate any help provided to set me back on course.
    mafandtranny.hpt 95degrees.hpl 73degrees.hpl
    13,607
    Commanded AFR is stuck at 12.84, are you stuck in PE mode?
    Is the scanner correct?
    Didn't look at tune.
    Jun 2016
    Fort myers, FL
    14
    I forgot my laptop moved and bounced the connector, I posted the other one that says 73 degrees
    13,607
    The 95 degree log has an issue, the commanded AFR is stuck at 12.84 while the 73 degree log is normal with the commanded AFR back at stoich.
    That is likely why you see such a huge difference. I wouldn't trust that first log at all, something is clearly off with the numbers as it shouldn't ever be stuck at 12.84 commanded air fuel ratio under normal operating conditions.
    Jun 2016
    Fort myers, FL
    14
    That was my fault, my cord whacked my work lunchbag and came loose so plugging it back in skewed those numbers a little.
