How are you guys reading/logging boost on a LMM Duramax.
Logging MAP in the Scanner doesn't seem to work as it is way low. Replaced the MAP sensor with a factory GM one and still the same. At key on engine off it reads 76kpa when the baro reads 89 kpa. But the output voltage of the sensor is correct. I checked it with my Tech2 scanner and the voltages are the same but the readings with HP Scanner is 76kpa when the reading with the Tech2 is 89kpa. So i cant use MAP to log boost.
With stock tune the thing smokes when you accelerate, so I'm trying to figure out if there is something wrong with the turbo.
Thanks Rick
