Page 2 of 7 FirstFirst 123456 ... LastLast
Results 21 to 40 of 134
Thread: MPVI2 Bluetooth
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    One of you should generate a ticket to support if you already haven't
    Ed M
    [email protected]
    Same Here, no connection and tried all the above. I was able to get in via usb.
    28,313
    Quote Originally Posted by mowton View Post
    Ed M
    Having a half dozen tickets or more for the same thing won't necessarily help with this particular issue. We are looking into it further.
    Quote Originally Posted by rpmextreme View Post
    Something is up with these. hopefully HP Tuners will chime in with some details before this thing goes off the rails..
    I received an email from support and they have acknowledged the issue. They said they should have a fix Monday hopefully.
    28,313
    Quote Originally Posted by MustangKiller View Post
    Yeah our hardware designer is testing a new firmware update. Not sure if all the MPVI2's were affected by the issue or if I just got lucky with my pre launch hardware
  6. #26
    I already emailed them Bill the moment you told me yours worked fine.
    Subject: [#133162]: Blue tooth will not connect
    ====== Please reply above this line ======
    Thank you for contacting support Bryan,
    We are aware of this issue and are currently working to create the fix. I'm being told it should be sometime monday when it's completed.
    Eric Krupp
    HP Tuners LLC
    www.hptuners.com
    M-F 9-5
    Ticket History(HPT Client) Posted On: 08 June 2018 08:21 AM
  7. #27
    im sure it will be fixed soon probably a firmware problem/bug. Just wanted to make sure it wasn't just me. Thanks
  8. #28
    Feb 2015
    Las Vegas, NV
    38
    I have one doing the same thing . In for info
    Doc
    Doc's Performance & Dyno Tuning - Las Vegas NV . Tuning any and all cars!
  9. #29
    Mine is showing WT12-A and will not stream data from the car via Bluetooth (but does with the cable)
  10. #30
    28,313
    New firmware version 2.0.79 published. it should fix the bluetooth issues that some of our customers were having (MPVI2 not showing up when pairing)
    There are a few options for updating to the latest firmware:
    1) For any 4.0 or 4.1 VCM editor: Help->Resync Interface will trigger a firmware update
    2) If using beta 4.1.68 or later gathering info will also cause the firmware to update.
    If you continue having issues with the newest firmware update email support please.
  11. #31
    Dec 2006
    Birmingham, Alabama
    156
    So that appears to work with the scanner. At this point is bluetooth only working with the scanner and not for the editor reading or writing?
  12. #32
    Sep 2002
    Chicago, IL
    6,397
    You can read vehicles in VCM Editor, just not write.
    We got this guy Not Sure, ...
  13. #33
    ok so yes the Bluetooth is working on the scanner but I am unable to read a file out on the editor. Not a big deal but the editor is not recognizing the MPIV2
  14. #34
    28,313
    Quote Originally Posted by RickClarke23 View Post
  15. #35
    Jul 2018
    22
    Any chance the mpvi2 will connect to a MacOS box so that I can relay the bluetooth stuff to vmware fusion with windows 10?
  16. #36
    28,313
    Quote Originally Posted by JasonCzerak View Post
    no.
  17. #37
    Jul 2018
    22
    no.
    Aaaahhh shucks. How about a Mac version of HPTuners?
    I'm mostly against wires, but when the pro version comes out and can log on it's own that'll be sweet. I guess I'll cope with plugging the mpvi2 into the laptop to pull the data.
    Thanks for the hard work on these things.
  18. #38
    28,313
    Personally I've just been using the MPVI2 paired to our track addict software via BT for now.
  19. #39
    Aug 2018
    17
    I just got an MPVI2, and I did connect it to my win 10 laptop, but the editor will not read/write, it doesn't find it. It finds if if I plug it into the laptop with a USB cable just fine....Is bluetooth only for the monitor maybe?
  20. #40
    Sep 2006
    Syracuse, New York
    299
    Quote Originally Posted by mat_holland View Post
    As far as I'm aware, BT is only for scanning.
    Writing must be done with physical cable.
    Not sure I would trust wireless for a write process anyhow. I'm sure that was the motivator behind the method
