Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 80
Thread: Help with Active Exhaust valve control on 6th gen Camaro SS
  1. #41
    May 2003
    South FL
    1,405
    I tried re-scanning for parameters with 4.1.064 and it did not find any extra PID's. Still the same 5 exhaust valves ones but I still did a datalog. Not sure if this will help.
    14.hpl
    [email protected]
    Owner/GM Calibrator
  2. #42
    HPT Employee Engineer@HPT's Avatar
    fecadefa
    615
    Please send support an infolog and debug.dat.
  3. #43
    May 2003
    South FL
    1,405
    Do i use the scanner or the tuner to pull those?
    [email protected]
    Owner/GM Calibrator
  4. #44
    fecadefa
    615
    Debug.dat is located in \Documents\HP Tuners\Settings
    You can get an infolog by hitting the blue i button in editor or scanner.
  5. #45
    May 2003
    South FL
    1,405
    Quote Originally Posted by Engineer@HPT View Post
    Just sent an email to [email protected] as requested
    [email protected]
    Owner/GM Calibrator
  6. #46
    Jan 2004
    Columbus, Ohio
    213
    I was only able to locate five of the parameters you listed above. Just emailed a 26 minute log showing all four driving modes.
    0:00 to 6:xx = Tour mode
    6:xx to 12:xx = Sport mode
    12:xx to 18:xx = Track mode
    18:xx to 26:42 = Snow/Ice mode
    Hope this information is helpful to you.
  7. #47
    fecadefa
    615
    I believe I've located the issue affecting those extra scanner parameters. Please download 4.1.072 and give it one more try.
    Thank you for your help and patience.
  8. #48
    May 2003
    South FL
    1,405
    Yup I see them there now, I'll get a log for you as soon as I can. Do you need me to cycle through modes at all? Typically I drive in Sport.
    [email protected]
    Owner/GM Calibrator
  9. #49
    fecadefa
    615
    I would just monitor them as you drive and take notes as to the values each of the extra 4 pids indicate. It should be pretty obvious how they are used after a drive.
    I will relabel everything accordingly once I have a log.
  10. #50
    Jan 2004
    Columbus, Ohio
    213
    Took another scan for you this evening with all nine of the parameters you requested, and emailed a log showing all four driving modes.
    0:00 to 5:00 = Tour mode
    5:00 to 10:00 = Sport mode
    10:00 to 15:00 = Track mode
    15:00 to 26:42 = Snow/Ice mode
  11. #51
    May 2018
    13
    Quote Originally Posted by Tapout Tuning View Post
    Could you possibly upload that log to here so I can check it out also since I don't access to all 9 PIDs.
  12. #52
    Jan 2004
    Columbus, Ohio
    213
    Quote Originally Posted by EMTNLSS
    2018 ATS-V M6 Exhaust Valve Test 2.hpl
    2022 Cadillac CT5-V Blackwing (733 whp)
    2022 Cadillac CT4-V Blackwing (716 whp), 10.750 @ 134.77 mph
    2016 Cadillac ATS-Vs (eleven ATS-Vs in the 9s)
    2008 Pontiac G8 (first G8 in the 10s), 10.727 @ 129.87 mph
    2000 Bonneville SSEi (first 3800 Bonneville in the 10s), 10.711 @ 125.71 mph
    1999 Grand Prix GT (first 3800 FWD in the 8s), 8.902 @ 154.90 mph
    1998 Firebird (first 3800 RWD in the 8s), 843 whp, 8.991 @ 152.12 mph
    1998 Grand Prix GTP (first 3800 FWD in the 10s), 9.499 @ 145.13 mph
  13. #53
    fecadefa
    615
    Thanks a lot for the help. This makes things much easier.
    Based on the log you submitted, regardless of driving mode selected, the car is using just one "performance mode." It indicated mode 1 throughout the entire log, so you only need to modify Exh Valve Close % 1 and Exh Valve Open % 1 tables. A value of -1 in these tables means the valve is fully open.
    Your RPM thresholds are in the Exh Valve RPM Thresholds table. Again, only need to change Close 1 and Open 1 rows. Just 3 tables to edit.
  14. #54
    May 2018
    13
    Hmm interesting. My car seems to be using the Exh Valve Close % 2 and Exh Valve Open % 2 tables based on what i've seen from just the 5 PIDs I have. Wonder if that means my car uses Mode 2 then. Wish I had those extra PIDs just to make sure. I'll start changing the Exh Valve tables and see what happens.
  15. #55
    Oct 2017
    Charlotte NC
    101
    Are you both sure you weren't controlling the exhaust using Driving Modes ->Engine Sound Management with a fixed setting other than 'Auto'. Maybe one was Sport the other Track. Just a guess as I would think the values would change.
  16. #56
    May 2003
    South FL
    1,405
    I took a datalog last night but only 2 of the 9 tables were reporting anything, which is strange because last time when I only had 5 PID's all 5 reported something. I think I need to re-poll again on the .072 version then take another log. I can probably get one this evening.
    [email protected]
    Owner/GM Calibrator
  17. #57
    fecadefa
    615
    Yes, you likely need to repoll.
  18. #58
    fecadefa
    615
    Latest beta 4.1.083 should have the extra pids available for FSCM_F (Camaro among others) guys as well. I'm not 100% sure they are correct so would appreciate it if someone logged them.
  19. #59
    May 2018
    13
    Ok so all 9 PID's show stuff for me now. From just switching modes in my driveway it looks like
    Stealth = Mode 3
    Tour = Mode 0
    Sport = Mode 1
    Track = Mode 2
    I'll get a log of them while driving later.
  20. #60
    May 2003
    South FL
    1,405
    I was able to see everything after a re-poll. Here is a datalog from last night.013.hpl
    [email protected]
    Owner/GM Calibrator
