Results 1 to 7 of 7
Thread: Air intake temp sensor
    May 2018
    Manitoba, Canada
    23
    Hi I was wondering if I could run a seperate air intake temp sensor instead of the one in the maf sensor. I installed a "cold air intake"
    which only draws in the hot engine bay air but also gets the temp sensor quite hot which I believe is causing the engine to become very sluggish when hot. The timing goes down to -10deg when accelerating from a stop. I disconnected the temp sensor in the maf which makes it better but it always reads -40. Any ideas?
    13,627
    Sure if you want too. Most move it closer to the filter end.
    Sounds like other issues if the timing retards all the way to -10 degrees without any actual knock and just high intake temps.
    I installed one in my intake. Order the Delphi sensor with the harness to make the job easier. I also ordered a new MAF harness-harness online for 12$ so I don?t destroy the factory one. The -40 is the default failure setting. Found that out not plugging the harness for the temp sensor in all the way
    May 2018
    Manitoba, Canada
    23
    The timing only retards to -10 on hot days stuck in traffic when acceling from a complete stop. When the engine is cool it runs excellent but I had noticed the intake air temp climbs to 145-150deg in 85deg weather. Can anything else cause this type of issue?
    if You pull in hot air from engine bay, IAT can get up there pretty high. Is the air filter in the engine bay or did you use the factory air box? I have found better results adapting the factory air box as it pulls in cold air from outside the engine bay.
    May 2018
    Manitoba, Canada
    23
    I couldn't find a factory box for this engine so I bought the aftermarket pipe that has the filter in engine compartment behind the left headlight.
    I added a new temp sensor and mounted it low near the bumper.
    Jun 2018
    Awful hot down here
    13
    You need to get rid of that hot air intake ... box it in, get outside air!
