I am looking for a stock tune for a 2005 silverado with 6.0LQ4 with 4l80 trans. my opperating system is 12592618
Switching from 5.3 4l60 to a 6.0 4l80
I have the stock tune for a 2001 Silverado 1500HD. It should be close, it has the LQ4 and 4L80E. In case it matters, it is a 4x4 as well.
try checking the tune repository, I just checked and its back up and running now.
2001 is DBW and 2005 is DBC
Flip that around, cable stuff went away after 2002 but not in the vans until like 2006.
haha im dislexic
I did what I said above. It was a lot easier than thought it would be to do. I left the transmission side alone and swapped the engine and engine diagnostic with a compatible 2005 V8 OS. Hopefully I'll give it a crank in the next few days.
