Could some confirm or deny my scenarios, or provide a better answer?
Hello all, new guy here having similar issues. Seems if I set po420 & po430 to 3-no error the catalyst monitor goes to complete and does not reset. This is a problem because the emissions inspectors check that they reset. Also, the codes are still in there as permanent. Hopefully someone with more knowledge can help with this. I am stuck because I can?t get plates without emissions passing. I need to drive to get emissions to pass. I can get temp, but it?s limited so I need to get this right first. Thanks
07 Silverado 5.3 full exhaust, CAI, BTR Stage 2 turbo cam and springs 226/231 .605"/.598" 113+4
I had the same codes on mine. To fix it I bought the anti foulers and put them on the rear 02 sensors until the code clears. After the code clears I changed the dtc to no error reported
Having same issu on Suburbian 5.3 Flexifuel, tested write cali and full, they are still there.
There is already adaptors placed, and still got the codes.
So, any pro tip for this weird stuff thats happening for many people.
Stuff the rear adapters with coarse steel wool.
2013 OBM A6 CTS-V Coupe
Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
2006 Black Raven STS-V (Traded In)
Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
