Results 1 to 10 of 10
Thread: Limiting output horsepower?
    Tuner in Training Pappacosworth's Avatar
    May 2016
    Finland
    44
    Car is 2007 4.6 auto, Vortech V3 without cooler, GT500 injectors, better fuel pump. How can I limit power for street. I need safe way to limit power to about 360 hp. Can I limit throttle opening/rpm, retarding sounds bad.
    Oct 2016
    Poland
    1,765
    You can limit the pedal output.
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Pull timing. It's one of the most effective and safe ways to limit power to forced induction engines.
    9 sec Montecarlo SS
    May 2016
    Finland
    44
    Car doesn't have cooler, so IAT pulls already so much timing, there is not much left to take
    Advanced Tuner small tuner's Avatar
    Nov 2015
    271
    lower rev limiter
    Nov 2009
    Pegasus Galaxy
    919
    Install a larger pulley to lower boost.
    You can also play with the Driver Demand table, it will request less torque if you lower the values in the table and the PCM will use timing and throttle to achieve the requested torque.
    9 sec Montecarlo SS
    Nov 2009
    All Around
    3,149
    pull ignition yet not too much so the plug can burn the mixture properly, or as mentioned swap pulleys
    May 2016
    Finland
    44
    Driver demand didn't work. I limited throttle and put last column 6500 rpm in spark to 5. Dropped 40 hp, but with smooth curve and nice torque.
    Advanced Tuner Auto-Hentzschel's Avatar
    Sep 2015
    Schleid, Germany
    341
    don't limit the throttle angle so much. It can overheat your blower! best way is lower the boost.
    May 2016
    Finland
    44
    don't tell anyone, it was only temporary limit to have document.
