Results 1 to 11 of 11
Thread: Pe enrichment wide open maf tuning
    Mar 2017
    Celina, ohio
    20
    Having an issue with wide open maf tuning. Adjusted mad curve 2x and no change to afr. Staying around 16. Had a fuel pressure issue but fixed it. No change. 99 c5 with ls3 with stage 3 cam, headers. I dont know how to attach log file or tune
    2008 corvette. Ls3 with tsp stage 3 cam, American racing headers, catless x pipe, vararam snake charmer sc1r intake.
    Aug 2009
    Calibrating
    3,379
    What injectors?? If stock then it?s bc your out of fuel...
    What?s IDC? If it keeps going up with no change then there ya go
    Oct 2014
    39
    In the bottom right there is a button to click that says ADVANCED click here, then click ADD FILES, " browse to you log file and double click it, then click UPLOAD, then look slightly below that were it says INSERT INLINE and click that and then DONE.
    Doug...
    Mar 2017
    Celina, ohio
    20
    Files. Maf curved adjusted and no change. Log is of adjusted maf curve
    Mar 2017
    Celina, ohio
    20
    Ls3 stock injectors. Due just fine in identical motor in my c6
    Aug 2009
    Calibrating
    3,379
    Ok ls3 injectors fine, thought you had 99 ls1 injectors
    Mar 2017
    Celina, ohio
    20
    Updated ls3 injector , changed a few more pe enrich tables but nothing changes anythibg
    13,615
    What if the wideband sensor is bad?
    Sep 2008
    1,668
    Look at his narrow bands, the wideband is right.
    2023 Durango Hellcat
    Sep 2008
    1,668
    How's your fuel pressure?
    Apr 2007
    1,104
    oxygen sensors can not read raw fuel. put it in SD mode and see if the o2's react at wot.
    93 Ranger. 5.3 D1X. 1069hp.
