I have a Sai Li twin pump return fuel system on my 2016 Mustang. On the inferred pressures do I set the all to my base pressure which would be with the boost/vacuum line unhooked? Anyone have any tips?
This is your delta pressure (base fuel pressure with no vacuum or boost).
These are 4 bar systems (coyote) base Should be at 55-58 psi
