Results 1 to 20 of 40
Thread: 2018 shift limited to 7400
    Feb 2016
    35
    I am having a hard time finding the limiter preventing shifting above 7400 rpm. Any ideas?
    Oct 2016
    Poland
    1,765
    E85?
    You are lucky - EU tunes won't shift above 6500 rpm unless using paddles - support says there's nothing extra to decode...frustrating.
    Feb 2016
    35
    I cant imagine..........Need all that rpm
    Oct 2016
    Poland
    1,765
    For me it will always up-shit @ 6500 rpm no matter what is commanded or which drive mode used.
    Feb 2016
    35
    Did support verify that is the limit? That was the first hurdle I had, 6500
    Oct 2016
    Poland
    1,765
    Nope, they said there's nothing extra in EU tune that can cause it. I tried everything - there's either something not available or something that I'm missing.
    What did you do to shift it over 6500?
    Feb 2016
    35
    This is not a file I would run around on. Multiple issue with it and downshifting is spastic. If you can compare with the EU tune and it fixes your issue let me know. I will send a good file to you.
    Oct 2016
    Poland
    1,765
    Nope, nothing new. Tried raising all shift tables a lot - still nothing.
    Feb 2016
    35
    What limits is it hitting? Source?
    Oct 2016
    Poland
    1,765
    It hits nothing - it would just up-shit @6500 rpm like nothing ever happened.
    Feb 2016
    35
    What rpm does it shift at stock?
    Feb 2016
    35
    Restore table 40070 to stock?
    Oct 2016
    Poland
    1,765
    Stock shifts @6500 - I was not able to modify that.
    Feb 2016
    35
    I would be interested in comparing your tune or the base tune file.
    Jul 2018
    Texas
    214
    Possibly high pressure pump speed limit under fuel pump tab?
    Oct 2016
    Poland
    1,765
    Quote Originally Posted by DGS View Post
    Hmm, will try that.
    On second thought HP pump is driven by EX camshaft so with 4 to 1 crankshaft ratio so 2000 rpm pump is good up to 8000 rpm crank.
    Oct 2016
    Poland
    1,765
    Quote Originally Posted by turbojim View Post
    2018 Mustang GT AT - STOCK EU.hpt
    Feb 2016
    35
    I will try that this afternoon.....thank you
    If traction control is not fully off it will short shift every gear even if you are no longer spinning tire. Also raise transmission protection, transfer case protection, and trans IPC.
    Oct 2016
    Poland
    1,765
    Quote Originally Posted by MaximumVelocity View Post
    Done that but to no avail.
