Results 1 to 11 of 11
Thread: Big Cam Idle Issues
    Jul 2018
    8
    Big Cam Idle Issues
    I'm working through a tune and am having the following issues:
    1. In OL and CL the car idles fine. Once CL occurs and I blip the throttle it hangs around 1200rpm
    2. Once CL occurs and I attempt to put the car in R, it will die unless I hold throttle
    3. Is it normal for LTFT to creep to negative for 1sec and return to normal?
    Any feedback would be greatly appreciated.
    Log files attached
    6.0L
    FAST 102
    42lb injectors
    SNS Stage 3
    3600 stall
    Stg 2 243's
    Only DTC is due to MAF being turned off.00 TA 09152018.hpl00 TA 09152018-2.hpl00 TA 09152018 PT Idle.hpl
    Apr 2011
    Chicago, IL
    763
    Im mobile atm so cant view logs until tonight but sounds like you need to get your base running airflow dialed in - the vehicle will always require more airflow in gear than park/neutral... the hanging idle I'd re evaluate once you get the idle airflow dialed in - throttle cracker is normally the culprit for a hanging idle but usually during coastdown but I guess it's possible
    Define normal for fuel trims - i always shoot for a -5 average during summer so when cooler weather hits itll still be ok
    Jul 2018
    8
    No worries! Let me know when you can. I have about 10% more idle air in Gear than P/N. I have the cracker disabled. As of now I haven?t driven the car.
    I can post the tune as well.
    13,601
    I'd almost say because it runs and idles just stop there and go straight to fixing the airflow model. This was it will make idle tuning that much faster.
    Forget about closed loop right now and go open loop speed density to fix the VE table to get fueling dialed in with a wideband. Enable closed loop again once the VE is corrected.
    Apr 2011
    Chicago, IL
    763
    yes, always post the tune so others can see as well but yeah the fueling is off quite a bit - it just pegs rich (ltft stops at -16% and stft peg -40) and resets so like 5fdp stated get the fueling inline - your going to need to remove fuel and maybe add like 10% more air for in gear idle airflow and see if it gets better putting it into gear
    Jul 2018
    8
    Quote Originally Posted by TCSS07 View Post
    TCSS07 Thanks!
    Here's the tune for reference:00 TA 08192018_Rev 2.hpt
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    You have waaaay too much under/over speed spark correction and looks like a pretty big cam (little or no vacuum) or a major air leak. Recommend putting spark correction back to stock (or even zero it) to see if it idles. If it does not, then your air models and/or PID settings are way off as well. One thing to remember is if you have the air (PID, VE and MAF) close, then your idle spark should be hovering around your desired which is 18 degrees...sometimes you have 18-20 but your rpms are well below the desired of 975 rpm which means you have driven the underspeed to its max....of 18 degrees! so you are starting with little or no timing which mean it is pulling it down to lower idle rpm (over desired)....
    Also at operating temp you are looking for the IAC counts to be at 50-80 steps/<.7 vdc.....and enough room at cold to not not max out count (310) during cold start.
    Also ETC (Electronc Throttle Control) plays no role in an IAC fitted platform so changing it is not required....the effective area vs IAC steps will determine the scalar for the IAC. What size throttle body do you have?
    Use these channels, check for vacuum/air leaks firs, dial in the MAF and VE to idle rpm and even a little below, then go for the idle.
    What cam are you running for the records?
    Ed M
    [email protected]
    Jul 2018
    8
    Ed,
    Thanks for your insight and direction.
    Cam: Tick SNS Stg 3
    TB: 102mm
    I'll work on the tune and report back.
    Sep 2017
    736
    This cam is similar to mine but different platform.
    How do you go about getting a good idle. Surely this cam, you cant really depend on the wideband or O2s at idle.
    How do you avoid cam reversion and split trims at idle?
    Aug 2009
    Calibrating
    3,378
    Needs more air and don?t count on 02 sensors making the correct fuel adjustment
    Sep 2017
    736
    Yea kinda gotta give lt what it wants ..
    I did away with O2s for now snd kinda like it
