Results 1 to 7 of 7
Thread: Manifold Temp Calculation
    May 2017
    6
    Hello,
    How is HPtuners calculating Manifold Temp in latest version of the scanner. I know its not a sensor as my car does not have an intake manifold Temp sensor.
    Thanks,
    Rob
    2014 Cadillac ATS LTG 2.0 Turbo A6
    Oct 2017
    Charlotte NC
    101
    I would like to know this too for Gen V Corvettes.
    May 2017
    6
    Guess i'll open a ticket with support. Thought they monitored the forums as well.
    Australia
    1,998
    MAT is usually the bias between the IAT and ECT sensors, cylinder charge temp bias determines the temp readout all zero's makes it same as IAT and all 1 makes it same as ECT
    May 2017
    6
    Well my IAT2 drops when under a WOT pass and coolant temp stays the same but manifold temp shoots up by 30-40deg So they must be calculating from somewhere else?
    Australia
    1,998
    not sure then im use to the LS style, u can just unplug some sensors IAT and ECT see if it directly changes the MAT reading, if it dosnt change at all then not sure where its getting a calc from
    May 2016
    Adelaide, Australia
    246
    Keep in mind hp tuners aren't calculating anything, they are reporting what the factory ecu is calculating. Your question should be directed to the gm engineers that coded the ecu.
