Results 1 to 10 of 10
Thread: TCC lowering mph
    Jun 2018
    41
    TCC lowering mph
    Trying to get my converter to lock up at a lower mph. It is locking up at 60 right now. I did check my tire and gears on the wizard. They are correct and my speedometer on the truck and the scanner match. I have been playing with the release and apply. Before it would unlock if you gave it any throttle at all. Now it stay engaged like I want but just need the speed correct on it. It is a 4l80e 3800 stall with a HD transgo in it. I got it shifting good. I 'm still tuning the motor so I have not been able to get on it to see how hard it shifts in performance mode. The motor does have a pretty big cam if that matters. Thanks in advance.
    Jun 2018
    41
    bump
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,256
    Make the changes to your Trans Rev/mile. The way you had it, the calculated tire size was only 19.59 inches tall.
    Russ Kemp
    Jun 2018
    41
    Will that make my speddo wrong? Right now it is dead on. I put the 27.09 in the wizard for the tire size. Before I had it screwed up and reading a 34" tire.
    Dec 2005
    Regina, Sask.
    4,256
    No, it won't affect the speedo. It is for the speed that the trans shift points are based on.
    Russ Kemp
    Jun 2018
    41
    3,839.9412 is what my tuner has in it. What should it be for a 27.09 tire?
    Dec 2005
    Regina, Sask.
    4,256
    Look at the pic in post #3
    Russ Kemp
    Jun 2018
    41
    That is weird, when I open that tune it says 3,839.9412 but it said something else on his. What should it be?
    14,066
    Brah.
    The picture is post 3 says 2,776.8163.
    Give that a whirl......
    Jun 2018
    41
    Worked like a champ. Thanks
