Results 1 to 6 of 6
Thread: Changing displacement settings
    Tuner Pector55's Avatar
    Nov 2015
    Dover, PA
    186
    I've changed from a 5.7 to a 6.2 and I know many people go up in displacement with strokers, swapping in 6.4s, etc.
    I am also aware that changing some of the General | Type / Size / Displacement will put the car in "dyno mode."
    My question is.. is there a need or ability to ever change these? At this point, I left all 3 as 5.7.
    2013 Dodge Challenger RT Plus - Shaker
    Mar 2018
    Illinois
    873
    I thought if you don't change the displacement the result will be that the values entered for VE will be higher than normal.
    Nov 2015
    Dover, PA
    186
    Quote Originally Posted by Homer View Post
    That's my conflict. I feel as though I should change them but I am aware of changing them enabling dyno mode. There are 3 settings, perhaps 1 can be changed that make the calculations accurate. Right now mine are 5.7 and the car tuned just fine. I was mainly curious.
    Mar 2009
    S. Florida
    583
    It dumfounds me that the displacement in tune affects traction control and other things not related. I made the same mistake when I put the 6.4 in. Now have 5.7 in displacement and left 6.4 in eng size.
    Apr 2014
    706
    On the subject of these 3 fields (Engine Type, Engine Size, Displacement), airflow calculations are presumably based solely on the "Engine Size" parameter. I have seen no ill effects to ESP/TC when changing said parameter to reflect the displacement change.
    Nov 2015
    Dover, PA
    186
    Quote Originally Posted by B00STJUNKY View Post
    That's what I was looking for. I will experiment with mine and see how it goes.
