Results 1 to 13 of 13
Thread: I give up...still stalling
    May 2018
    Lake Worth, FL
    40
    I can't seem to fix the stalling issue or the negative timing on WOT.
    Should I get a remote tune done?
    May 2016
    1,134
    What kind of car?
    May 2018
    Lake Worth, FL
    40
    2012 Camaro SS
    May 2016
    1,134
    Cam? PM me if you want
    May 2018
    Lake Worth, FL
    40
    It's a TSP Stage 1 223/233, .629/6.29, 114
    13,626
    Not even a log or tune file?
    How the hell are we suppose to even help?
    Use magic power to see through the internet and onto your computer?
    May 2018
    Lake Worth, FL
    40
    Here's a log and tune
    my-tune.hpt
    mylog.hpl
    Jul 2018
    Texas
    214
    The Fuel/Oxygens Sensors/ Rich/Lean vs. airflow for Bank 1 and Bank 2 maybe should be 450 when compared to some other tunes. Yours are all different.
    May 2018
    Lake Worth, FL
    40
    I wonder if I should start over. I originally had it tuned by someone. The problem is, I don't have the stock tune.
    Total mods are the Cam I mentioned previously, DOD delete and long tube headers with cat delete.
    May 2016
    1,134
    Wouldn't have to change much to get it back to stock honestly. Pretty minimal changes. When does it stall? I didn't notice it stall in the log.
    May 2018
    Lake Worth, FL
    40
    Every time it stalls, I don't have the log on.
    Usually during idle in gear. It also stalls if I step on the gas and then brake quickly.
    Here's a quick log from when it almost stalled. I put it in neutral and it recovers.
    almost stalled.hpl
    Aug 2017
    22
    I had the exact same problem. Didn't check your tune or log, but symptoms were same as me. 2011 camaro here
    Fix : Idle-Airflow-Airflow Final Min - increase by 2g/s until no longer stalls at your RPM (200 - 1200rpm it looks like) I increased entire table by 2g/s. Continue increasing lower rpm range by 2g/s until it no longer stalls
    could also mess with throttle follower given the almost stalling when you hit the gas and then brake
    May 2018
    Lake Worth, FL
    40
    Thanks @who-dat. I'll try your suggestions and report back.
