Results 1 to 13 of 13
Thread: 14 GMC 6.2L BTR Cam
    Aug 2018
    15
    14 GMC 6.2L BTR Cam
    14DENALI_E92_6.2L_A6_Cam_BTR - Copy.hpt
    Did BTR Cam and have some warm start idle fluctuations. Also having driveline clunking pretty bad.
    Any help would be appreciated.
    Aug 2018
    15
    14DENALI_E92_6.2L_A6_Cam_BTR - Copy.hpt14DENALI_E92_PEREGRINE_6.2L_A6_STOCK_ORI.hpt
    i attached my Stock File and Modified Tune File for comparison if someone would be so kind to take a look.
    I did some tuning to TCM today using Bluecat and it has helped some. Hope I can get some more seat time to dial it in some more.
    Thank you.
    Aug 2018
    15
    14DENALI_E92_6.2L_A6_Cam_BTR _Trans_Change_SWP 1_13_19_Rev3.hpt
    Attached is TCM Tune I did with help of Bluecat. I still have plenty of clunking in driveline when I let off gas. Can't seem to get it out even with playing with torque converter lock up. Any help would be appreciated.
    Nov 2009
    All Around
    3,149
    would be best to post a log of your car idle /cruise
    Aug 2018
    15
    Added Log file and did some changes to tune.
    Changes from Tune from $900 Tuner...
    Lowered RPM down to 700. This fixed the drive-line "Clanging" when coming to a stop. I think it was due to torque converter engagement at that RPM. I do need to see if idle can stay just a bit more stable. It is much better than before.
    I changed a bunch of shifting times as MPH up-shift and down-shift. Also changed a bunch of torque converter lock-up and unlock.
    Changed Low, Medium, High VVT retard. Started at 3500.
    One thing I can't figure out is the light throttle 3-4 shift. The throttle closes during that shift and I want that gone completely. It is so annoying and makes the truck lunge. No reason for the throttle to close at that minimum throttle and 3-4 shift.
    Take a look and see if you anything else. My fuel trims look ok, but at lower RPM it is adding up to 10% fuel and at 3000 and up it is taking fuel away up to17/18%.
    Aug 2018
    15
    I am still getting drive line "clanging" at 7 to 10 mph coming to a stop. It feels like the lope from the cam is what you feel in drive line transitioning from cruising to stop. I have attached current tune file and stock is in thread.
    Would really appreciate some feedback from someone...
    Nov 2009
    All Around
    3,149
    14DENALI_E92_6.2L_A6_Cam_BTR _HPForum_test.hpt
    this is SD, get a idle log, there was alot of strange things going on...
    Aug 2018
    15
    Logs attached. Thanks
    13,607
    I wouldn't max out all the engine TM tables if this was my tune.
    Also wouldn't disable the TM stuff in the transmission either. The upshift/downhift torque reduction tables have been disabled.
    Aug 2018
    15
    Any feedback appreciated.
    Nov 2009
    All Around
    3,149
    14 6.2 Modified BTR Cam_Stock Trans_Base Idle Change_Trans Shift Times_3_9_19 blend.hpt
    use attached
    idle
    cruise
    and wot say 2nd gear
    make sure traction is off.
    Aug 2018
    15
    Drives great on highway, especially when flooring and letting off gas. Before the whole driveline would clang around.
    The transition going to idle is rough. The whole driveline clangs and bangs around from cam chop at low speeds and when idling. Low speeds have choppy idle and clunky shifts.
    What are your thoughts on log?
    Aug 2018
    15
    Huge thanks go out to MasTuning!
