Those are second best plugs for it IMO so you're good there unless you just wanted the gap a touch tighter to be a little safer. Also hope the plugs were checked before install and all gapped the same. They are to come pre gapped at .028" but in most cases are not. And even gap between all plugs is crucial in these engines based on how the ECU operates.
