Thank you, ZR1DRIVER. I understand now. I thought since you mentioned the chassis module that you knew a person at ACDelcoTDS that was nice. I am dieing to get better access to GEN4 and GEN5 BCMs.
here a small update after talking to dertobi. i was able to create a .xdf from the hex address where we are suspecting the torque reduction and put the definition in hp tuners.
the next days i will run some tests on the dyno but i?m sure we are on the right track.
wow thats awesome. How did you end up doing that? and where did you get the access to this? Im guessing winols was used or something to explore the rom. Is that what the custom parameter option HPtuners offers??? Best of luck in finding the issue
ZR1driver gave the hint that it must be in the system calibration...i fired up my Winols and found that pretty quick
I knew it must be in the ECM but I didn't know where to start searching, there are pretty much differences from US to EU model when you look at it in OLS
im too poor for winols lol good stuff.. maybe protuner RT could have worked too?
HP Tuners dont support this table. you need to know the adress in Hex and do the definition by yourself with user defined parameters.
i still have to check if it work but i'm sure it will.
Wow! Thankful for your research and input! And anybody stuck with that torque table should be even more thankful for a revision.
bzzzzz...let's keep it our secret
If you send the definition to HP Tuners they will usually add it to the Beta version.
Hey Guys,
what hardware do I need to write the corrections to the car? UCM BDM ??
HPT Editor - Edit - User Defined Parameters
https://forum.hptuners.com/showthrea...ned-Parameters
Hi to all,
I'm an owner of MY18 European Camaro 6.2 AT8... and I've the same issue.
I've HP Tuners
Could be great if someone share solution to this issue
Kindly Regards
