![Quote](images/misc/quote_icon.png)
Originally Posted by
95Gturbo
I went out to flash the updated file in Tim's VT earlier, there was an issue connecting to the hptuners server aborted. Checked my internet connection and all was good, with the key still on I tried to write again and it timed out. Try to start the car and the fans come on just like when you are doing a flash. I tried to do a write entire with both a modified file and the stock file, and it also timed out failed. The car is stuck in my work parking lot. I emailed support about it, but it isnt looking good at all. Has anybody else had this issue? After it had the failed to connect during the server request to Hptuners database, the fans were already running as if it was flashing a tune. When I tried again, the erase took longer than usual and then the write calibration which normally takes 40 seconds...showed 100 minutes, then 256 minutes, 788 minutes, then 1048 minutes before saying that it timed out and the write failed. Somebody please help, this is his daily anand only car.
