Results 1 to 12 of 12
Thread: LS1 2 bar pid
    Jan 2012
    Cessnock NSW
    73
    LS1 2 bar pid
    Hi, I?ve got an LS1 411 PCM with 2 bar operationing system, 2 bar map sensor, running a supercharged LS 5.3, engine and charger run OK but need further tuning.
    My problem is when I try to use the 2 bar map pid in th scanner it doesn?t work, I use the 1 bar pid and it works fine, I need the 2 bar pid to work so I can tune the booster area of the ve table, with engine off key on the map sensor will read 103kpa, when I load of the 2 bar pid it?s just stays 0, I?ve updated the software to the latest version.
    Iam I missing something here? Settings on the scanner etc? Iam lost ....... TIA
    May 2016
    Adelaide, Australia
    246
    Delete the one bar pid
    Jan 2012
    Cessnock NSW
    73
    I?ve deleted that one, thanks anyway
    13,630
    So that did or did not work?
    His point being that you can't log more than 1 map sensor channel, otherwise it will not read correctly.
    Jan 2012
    Cessnock NSW
    73
    I deleted the 1 bar completely then loaded the 2 bar channel and still doesn?t read
    13,630
    Did you re-poll for supported parameters before you added it?
    Can you post the log?
    Jan 2012
    Cessnock NSW
    73
    Yes I re-polled it, still didn?t fix it
    Dec 2008
    Nevada
    4,452
    do you have a tune file and scanner file?
    if i remember correctly the channel will not work if that os is not properly applied before re-polling for parameters.
    Jan 2012
    Cessnock NSW
    73
    I have the tune file, but what do you mean by a scanner file? You mean a log?
    Dec 2008
    Nevada
    4,452
    yes tune and log.
    you could even go one further and in the scanner software you can save your scanner configuration using the "Save Layout" option.
    all three can help us see what your dealing with and doing in the software.
    Jan 2012
    Cessnock NSW
    73
    Has someone got a known scanner layout that works I can try? Thanks
    Jan 2012
    Cessnock NSW
    73
    ls1 wideband.Layout.xml heres my scanner layout if someone can check it TIA
