Here's a timing calculator I built specific to UDC Pro table layouts, not sure if HP Tuners copy to excel the same or not. If not if some one provides me a spreadsheet with HP Tuners table layouts for pressure, duration and timing I can readjust. This calculator uses advanced background magic to find the values its looking for. A difference in axis values will not affect the operation of the calculator. Just make sure on the pressure, duration and current timing sheets the axis values are what you want if different than stock and it'll take care of all other axis values on the rest of the tables in the other sheets. This calculator shows more information as well than others do. It'll show you how changing for example pressure in one cell is going to affect the total injection duration. This calculator also has a "lookup" sheet where you can "lookup" any pressure, duration, timing(current and new) values for any given rpm and mm3/s.
If any one wants to see anything added to this calculator let me know and I'll see what I can do.
http://www.mediafire.com/file/k1soj6...ming_Calc.xlsx
