I don?t believe it is because I have gone down that path and checked it?s an S366 with a .065 restrictor due to having a -4an feed line. I had an exhaust leak at my downpipe before switching to a marmon flange for the turbo and smoke would come out of the hood prior to my retuning and it stopped. I left that semi leaking v band on to help determine if the turbo was having issues or not. After the smoke ceased at the turbo I tossed on my marmon flange. Dip stick is also sitting full every time I check in the morning. Also coolant is always full in radiator in the morning too. As I play with the tune with the car warmed up as soon as the car hits closed loop and then the trims decide to compensate the ?leanness? by adding fuel it smokes more closed loop than it will open loop. Could be possibly leaking exhaust valve seals tossing raw fuel out before top dead center?
