Results 1 to 9 of 9
Thread: stock pcm or 411
    Feb 2018
    NC
    16
    stock pcm or 411
    finishing a build and need some help on what pcm i need to use to try and use my vin. i have a 411 pcm from a 02 tahoe and my stock 2003 s10 pcm whitch one do i need to use to make it work. and what file would it need
    Feb 2018
    NC
    16
    the tuck is a s10 with a ls1....
    Feb 2018
    NC
    16
    some of the OS on the 411 were used for the s10. do i need to start out with a 4.3 03 tune or build of the 2.2 or flash a camaro tune?
    13,615
    Do you have emission laws that say the VIN must match?
    Because in reality the VIN does not need to be correct for anything to make the engine run. I am pretty much positive that you couldn't put a S10 vin number onto a LS1 computer, not with HP Tuners anyway.
    Oct 2008
    Mebane NC
    475
    We do have emission laws here in NC which I believe the OP is from. Depending on the year they do hook up and look, that being said the VIN will need to match.
    Jul 2018
    37
    the 03 is not a 411 ,the 411 is 01-02 v6 or v8 ,, i invested in tuner cats years ago just to flash vins and os
    Oct 2006
    Columbus OHIO
    31
    EFI Live can also change VIN. You can do all your tune in HP tuners, and when you are done, just have someone change VIN with EFI live, (you can do it with the 2 way tools.) You'll want to change it back if you need to do more tuning so you don't piss of HP Tuners.
    Dec 2011
    Clovis, CA
    374
    I can do whatever with the vin#. Just let me know. No need searching anyone out. I'm right here! I can make the v8 file and have the correct vin. No problem.
    Thanks,
    Dustin
    Sep 2017
    736
    If you have the right cable VIN changing software is free.
