Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: Parameter Templates now in VCM Editor 4.3.431+ (NEED BETA TESTING FEEDBACK)
    Aug 2014
    Central, LA
    738
    Quote Originally Posted by Keith@HPTuners View Post
    Removing individual parameters is already supported, and documented in the help file link.
    I see it now. Reading is hard
    Oct 2016
    Poland
    2,042
    2018 Mustang GT EURO tune "JR3A-14C204-BKK" is no go. Creates a template but says the file is wrong. Sometimes it will crash the Editor to point of restart.
    Oct 2016
    Poland
    2,042
    2017 Mustang GT EURO "HR3A-14C204-UC" works with one DTC exception but no biggie.
    Oct 2016
    Poland
    2,042
    Tested the other 2018 Mustang EU tunes I have just to give it a try and none of them works. Mostly crashing after selecting the parameters to import.
    Sometimes it will work eventually and you will be able to save .htt file but it doesn't work either way claiming the file is invalid.
    Sep 2002
    Chicago, IL
    6,411
    Hmm, could be a language issue.
    Please open a support ticket, attach the appropriate files so we can duplicate it and walk us through the necessary steps. We should be able to fix it ASAP.
    Thanks.
    We got this guy Not Sure, ...
  6. #26
    Oct 2016
    Poland
    2,042
    Will do. Thanks
  7. #27
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,877
    I just tried it on a C7 ZR1 FICM for injector data, and I got an error on table 49030 and 49035. It just said "Exception" at the end. I created a template by selecting the entire Fuel Control Module tab from an already modified FICM for ID1050X injectors, saved the template, and applied it to a stock FICM file. There was not actually anything different in table 49030 between the two, but 49035 was actually different between the two.
    Any chance we can use the template applicator for user defined parameters?
    http://www.dsxtuning.com
    Just say no to bull s***.
  8. #28
    Dec 2008
    on the Dyno
    1,825
    User Defined in the templates would be tits!! Especially since no compare file can be used for them yet so manually copying/pasting multiple tables is a chore.
    Located in Central Kentucky
    ShorTuning
  9. #29
    Sep 2002
    Chicago, IL
    6,411
    A new beta was just published that might fix the failures.
    If you are continuing to see failures, please open a support ticket.
  10. #30
    Tuner in Training bluessmax's Avatar
    Feb 2011
    Lake Charles, La
    19
    L5p (lots changed fwiw).. It is not working. When I compare the files - it will not show the differences also.
    Infatuated by advancing acceleration in one hell of an aggressive manner.
    PPEI.com
  11. #31
    Sep 2002
    Chicago, IL
    6,411
    Please open a support ticket so we can fix this issue for you.
  12. #32
    Feb 2011
    Lake Charles, La
    19
    I figured it out..
    For whatever reason - if the custom OS patch is applied so that the ECU disables VATS - it quits working. Set both base files up with VATS disabled (Or both enabled) and it worked. Looks like it just didnt like the OS segment modded.
    PPEI.com
  13. #33
    Sep 2002
    Chicago, IL
    6,411
    That shouldn't be the case. Can you open a support ticket so we can look into it?
  14. #34
    Mar 2008
    St. Louis, MO
    4,877
    Any chance of preventing the template page from completely blocking out the rest of the software while it's open? It isn't a huge deal if not.
  15. #35
    Feb 2011
    Lake Charles, La
    19
    Yes sir - slammed out busy on some updates - but will make ti happen.
    PPEI.com
  16. #36
    Sep 2002
    Chicago, IL
    6,411
    The applicator?
    That is currently a back end requirement, relating to parameter values and refreshing on change.
    I don't see that changing any time in the near future.
  17. #37
    Mar 2008
    St. Louis, MO
    4,877
    Not a big deal. The fact we even have these templates now is awesome.
    Next project is electronic differential and ABS module editing, right?
  18. #38
    Tuner MakesBadDecisions's Avatar
    Oct 2017
    Montucky
    194
    Maybe BCM editing??????
  19. #39
    Advanced Tuner Auto-Hentzschel's Avatar
    Sep 2015
    Schleid, Germany
    342
    Template applicator destroy the most table axis.
  20. #40
    Advanced Tuner Justinjor's Avatar
    Jul 2011
    Tampa, FL
    281
    Will template editor not allow you to modify the row or column values?
    i.e. - fuel pressure data for stock fuel system vs a return style fuel system - the psi values are different. I wanted to create some templates for the common injectors that we use but the template editor only lets me change the values but not the rows or columns so that makes it essentially useless for applying global changes to a tune file that needs the X or Y axis data updated.
    Am I missing something?
    2020 Mustang GT Daily driver
    |Hellion Sleeper|10R80|Full weight, full exhaust, BABY seat in the back|
    8.3@167mph
    2014 Mustang GT
    |Hellion TT|Powerglide|Ignite114|
    6.87@200mph
    Jordan Performance and Racing
