Baro pressure at cold, key on engine off is reading 32.5inhg. My baro pressure is 29.98 today, I'm located at 30 feet above sea level, temperature is 75
The engine is a 6.2L hellcat, the PCM is a factory unlocked Hellcrate PCM with nothing tuned in it yet.
As a side note I also have 32% fuel trim for both long terms.
My thoughts on this is that the barometric pressure sensor thats built into the PCM is reading incorrectly. I think the PCM thinks its at -2000 feet
What are your thoughts about the baro sensor reading?
