Results 1 to 7 of 7
Thread: Hellcrate High Actual Torque at key on - limp mode
    Oct 2017
    30
    Most time when turn the key to the on position I see a Actual Torque value of 1142. This is the same as Driver Demand Torque 1142
    The car is cold key on engine off
    Hellcrate motor, headers, CAI
    The file I included is after a long idle
    Codes are P0171, p0174, p2174, U1110
    hot re starts actual tq high.hpl
    What causes the value of Actual Torque to be high at key on engine off?
    Jul 2017
    33
    Is it running on the tune that came on the PCM? I just finished a swap and could look through some stuff later.
    Oct 2017
    30
    Yes completely un tuned. Would you send me stock tune (un modified) and or I can send you mine. I?d like to compare. They should be exactly the same. Can I see a running log too please?
    Mar 2018
    Illinois
    873
    Sounds normal to me, if the engine is not running, VCM scanner will report a high actual torque value. In fact, on my challenger if you look at the engine torque display with the engine on but not running it reports 412ft-lb.
    Jul 2017
    33
    I can get you some stuff and I will take a look at this log later. I completely forgot. Also, I actually screwed up and copied over my stock read. I have one that had some very small changes saved, so if I could get a copy of yours, I could correct mine and see if there are any other major differences that I can see.
    Oct 2017
    30
    Quote Originally Posted by unicornpower View Post
    Hellcrate Baseline Tune Stock 3.19.19.hpt
    No worries, here is the factory Hellcrate Tune un touched.
    Jul 2015
    927
    Quote Originally Posted by Homer View Post
    Yeah. A lot vehicles will show strange values with KOEO.
    OP is there an actual problem or were you wondering why it was showing that?
