Page 1 of 3 123 LastLast
Results 1 to 20 of 53
Thread: BIG Boost Hellcats. any ideas before i burn it?
    May 2019
    13
    i have a 17 cat and a 18 demon. both cars on demon sensors. two different blowers with two different throttle bodies with the SAME problem. i can make 22 psi all damn day long. making about 1050-1080 tire with clean pulls the second that either one of them tries to make more boost (dropping pulley) it shuts the throttle on me at the end of the run then a limp mode (sometimes). i have raised every single thing i can find in the software. i have tried tricking it into thinking it makes less tq. i have tried 2 bar map sensors thinking it was a max boost thing. NOTHING works. what am i missing? has anyone managed to make more than 22 psi on a Whipple. i need ideas. i will pay anyone who helps me solve this because that will be cheaper than burning the shop to the ground. i have attached a log where you can see it closing at the end before.
    Isn't a 2 bar map sensor only really good for 14 lbs anyway? Doesn't make sense that you'd be able to map out fuel for 22 lbs with a 2 bar sensor
    May 2019
    13
    Quote Originally Posted by Scottgt21 View Post
    Yes correct. They can be mapped to account for extra fuel quite easily. Im just saying i have tried the 3bar and the 2 bar. The only reason i tried 2 bar was to see if MAYBE it was having a issue with seeing 26 psi. But it still does it regardless. So the 3 bars will be going back in it.
    Im just looking why both cars are ok on 22 but pcm shits on me at 26. Lol
    Oh okay I was confused lol. Sorry I don't have any inputs
    Feb 2019
    Lewisville Texas
    38
    you mind sharing your tune? i can compare it to my trackhawk. im only at 16psi for now but i dont seem to have this issue.
    May 2015
    1,908
    likely an airflow or torque limit that either was missed or simply isn't mapped out in your tune. Does your torque source stay "pedal" during the shutdown? What does timing do during the shutdown?
    May 2019
    13
    Quote Originally Posted by 06300CSRT8 View Post
    the Tq source stays pedal the whole run and on the decel as well yes. timing stays commanded. just the throttle shuts. thank you by the way
    May 2015
    1,908
    need a copy of the tune to review
    May 2019
    13
    Ill pm you if thats ok
    May 2013
    14
    Sounds like cat-overtemp
    May 2019
    13
    Quote Originally Posted by SkipDMan View Post
    No unfortunately thats all raised. Im starting to think its a hadware issue. I think that maybe the motor cant physically keep it open. Otherwise im still lost.
    May 2017
    St. Clair, MI
    4
    Quote Originally Posted by just a nobody View Post
    May 2017
    St. Clair, MI
    4
    Can you send me a copy of tune, I had this same problem on my sons stroked R/T with a procharger.
    May 2018
    36
    Send me tune to [email protected] . I ran into the same issue on the dyno .
    Potential Tuner CamaroGirl5's Avatar
    Brighton, MI
    5
    Does anyone have an answer for this? Running into the same issue with a Magnuson powered trackhawk...
    Mar 2009
    S. Florida
    583
    Quote Originally Posted by CamaroGirl5 View Post
    Believe the answer is a three bar map sensor.
    I just did one 26psi on a whipple, but since you wont post a file how are we supposed to help
    May 2015
    1,908
    Quote Originally Posted by coanan View Post
    Believe all 2018+ hellcat/redeye/trackhawks come with 3 bars, not the issue.
    May 2015
    1,908
    Bumping this back up, having this identical issue, on an older 2014 but running a hellcat setup. Hitting limp mode / throttle closing once I upped the boost to around 21psi.
    could be transmission torque limits
