I am seeing some crazy KR on different logs that don't make sense to me one being 6.9 degrees pulled at a medium load low rpm scenario, Then ill log again on same day and get no knock in the same region but some in a a different region. When I Initially established my lower rpm VE table and finished up my MAF curve I recorded a long drive. I seen very little to no KR and fuel trims all looked decent, Now all that I have done in the tune since then is re-enable my DFCO and smooth my VE table using the smoothing function, and I reduced my Follower and Cracker tables to help with some low speed bucking. Now, I am getting a large amount of knock retard as shown in scanner, during 6th gear cruising usually at 1600-2000 rpm however I think it only happens after it is in a steady state, as ive tried to entice it to happen and I cant, it will just randomly pull large amounts of timing after cruising for 10-15 minutes... I thought maybe I smurfed my VE, but using the compare feature it really didn't remove or add that much fuel to the cells from before. What gives? Ill attach a few logs and the two tunes, hopefully somebody can help me determine if this is false or real knock and if I should pull timing, hunt for vibrations, etc... I do have a loud valvetrain, big cam, dual valve springs and morel lifters, unsure if aftermarket heads with bigger valves also transmit noise differently so ill include those..
final tune, VE smoothed DFCO on TC&TF adjusted KR present 2.hpl
final tune, VE smoothed DFCO on TC&TF adjusted KR present.hpl
Final Tune VE smoothed DFCO on TC&TF adjusted.hpl
VE Smoothed, DFCO on Throttle follow 2000 to 0 zerod TC reduced low rpm&speed area.hpt
Final tune DFCO On.hpt
Here are some logs and the two tunes that show my only changes to the tune, one of which is pulling a degree of timing from the 1400 rpm cell due to some slight kr I noticed in a previous log. and the other being smoothing the VE table and reducing my cracker and follower tables. Hopefully someone knowledgeable can take the time and chime in.
