Hello from Belgium, I am a newbie.
I own a Mustang 2017 GT V8 Europe non PP (non Performance Pack).
I installed a double gauges on the middle of the dashpanel (Oil Pressure & Vacuum) as a PP-model. Once the wiring is completed (from OEM APIM Sync), Vaccum gauge is alive but not the Oil Pressure gauge.
With my VCM Editor, I changed a thing in my tune for the ECU to broadcast the actual oil PSI.
The non Performance Pack GT's use a dummy 'switch' but when you change the 'Oil Pressure Config' from 'Switch' to 'transducer' (see form General Engine), my oil pressure gauge is now alive ! fine ! between 40 to 80 PSI.
But now, after every engine start, the car has the 'low oil pressure' light come on. I understand well, the pressure information is now used by the gauge and the ECU dummy 'switch' receive a pressure on null.
How can I disable this warning message ? Thanks for your help and sorry for my poor English![]()
