Cannot add AEM Wideband 4110 channel
I have the HP Tuner Pro with prolink, and I cannot get my aem wideband 4110 added as a channel in the VCM scanner.
I connected the red prolink wire to the white aem wire, and then the black prolink wire to the black aem wire. The gauge is working, but I cannot get it added to the scanner. The only thing listed under the MPVI2->Prolink is Red wire (Voltage). That is the only thing that I can get to come up.
I also need to add that this is for a non-CAN car (2005 grand prix)
Any ideas what I'm missing?
Once you add the channel (Prolink voltage), right click on it and select transform.
In the Transform Selector window, navigate to Oxygen Sensors / Air-Fuel Ratio (or Equivalence Ratio if you're using Lambda). Then select the 4110 from the list.
However, I'd set it up as user defined just in case you need to correct any analog offset.
Reading around in this section should be helpful.
Yes. That's what I ended up doing after watching this video on Youtube. About the 4:07 mark it explained the part that I needed. Thanks for the reply.
https://www.youtube.com/watch?v=u_LRPb3l1DU
Thanks this was really helpful.
