Results 1 to 10 of 10
Thread: 97/98 LS1 Corvette PCM swap
    Oct 2017
    14
    Hi Team
    We have been asked to help out with a PCM swap for a 97/98 LS1 Corvette, we will be replacing with a 2001 Holden LS1 PCM (Serv No 12200411), this is due to PCM failures whilst using HP tuners (yes I have notified support, whom have no answers for me unfortunately)
    I have pinouts already
    I have attached the standard 97/98 tune, does any one have any info as to what Year/OS tune we need to write to the newer 411 PCM to carry out this conversion
    I have tried doing a write entire of the 97/98 OS to the newer 411 pcm, it does not work at all
    Any info would be much appreciated
    Phil
    May 2006
    22
    most use the 2002 LS6 Corvette tune file
    405
    2,378
    Quote Originally Posted by dynotech View Post
    Phil
    If you really tried that don't attempt any more writing until you have a lot better understanding of how this all works.
    Oct 2017
    14
    Thanks for your reply.
    Rest assured i did this on advice from hp tuners support team, which obviously is incorrect
    Do you have any input or relevant file to help?
    Oct 2017
    14
    Quote Originally Posted by mild7 View Post
    Do you have a copy of said file or OS number?
    Brisbane, Australia
    165
    I actually have a 1998 LS1 Firebird PCM in my garage if you need to get a replacement for the original.
    If you are still going the 0411 swap route, you should be able to use any of the Holden Commodore 00-02 LS1b tunes for this.
    Once you have the OS on there, you can open the corvette file and copy and paste the spark/fuel values etc back over and make any changes needed manually.
    Might be a bit time consuming but I think that would do the job.
    I have a fair few of the files somewhere at home when I was searching for a starting tune for my 0411PCM swap if you need one I can send.
    Disclaimer: by no means an expert, most other guys here would be better suited to answer the questions, but as an aussie I might know a thing or two about the commodores the others don't
    Oct 2017
    14
    Much appreciated
    If you wouldn’t mind sending to [email protected]
    We are using a vx ecu
    Quote Originally Posted by evilstuie View Post
    Brisbane, Australia
    165
    No worries, 4L60E auto?
    Oct 2017
    14
    Yes 4l60e
    Brisbane, Australia
    165
    Sorry dyno, been flat out with getting my car on the road and forgot about you LOL
    Here's a VX commodore tune and a 99 camaro tune.
    You could try either of these and then copy and paste your spark and fuel tables over and should be good to go.
