Page 5 of 5 FirstFirst 12345
Results 81 to 97 of 97
Thread: 2009 lsa cadillac after dyno tune? Criuse tuning help
  1. #81
    Jul 2019
    JAMESTOWN, ND
    54
    Quote Originally Posted by sgod1100 View Post
    Hotter air is less dense than cooler air. So there are less air molecules per unit volume in hotter air. If your tune is spot in in cooler weather I'm willing to bet your fuel trims will be pulling fuel out when its 90-100 deg. outside while in CL
    I wish it was only 100. Temps have been 110 last couple weeks
  2. #82
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    Do not have that issue on my tunes.
    2012 ZL1 - Maggie Heartbeat, Port & Polish Heads, Custom Cam, Custom rotating assembly, steel sleeved LS9, No NOS and No water meth. 16psi
    810rwhp and 820rwtq 91 Octane 6400 rpm
    948rwhp and 951rwtq 105 Octane 6400 rpm
    999rwhp and 997rwtq on 60% Ethanol 6400 rpm
  3. #83
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    476
    It is pulling fuel so I guess I'm not looking at it right. I see negative fuel trims as running richer so I try to adjust it closer to +/- 5%.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
  4. #84
    Jul 2019
    JAMESTOWN, ND
    54
    so I should do all VVE tuning first then MAF, correct?
  5. #85
    Jul 2019
    JAMESTOWN, ND
    54
    Quote Originally Posted by jsllc View Post
    Sometimes I wish I could say the same! lol
  6. #86
    Sep 2015
    Bozeman, MT
    701
    Guess you can do that way. I don't.
  7. #87
    Aug 2018
    295
    I'd bet tuning the injector tip temperature will fix you guys' ambient-temperature-related fueling swings... especially with those 1150cc injectors, Dzz88. If you tuned in the hot, 110 degree afternoon with a stock inj. tip temp curve, you're getting a lot of extra fuel dumped in there at low throttle inputs. Then, when you go for a drive at 7am the next morning when it's 70 degrees outside, you will be getting little to no extra fuel added. So basically- when you tuned it in the afternoon, you had a lot of injector pulse width adder that's no longer there in the am. If you are in open loop, it will go lean.
  8. #88
    Sep 2015
    Bozeman, MT
    701
    Yep, lots of posts about this. Some ignore this and deal with wide swings other choose to make the issue worse by zeroing the table out. Considerable time was spent on this and it always proves out. It has nothing to do with the manufacturer of the injectors. It is a construct of the ECM and software running.
  9. #89
    Nov 2004
    St. Louis, MO
    476
    Makes total sense and probably what we are seeing. I am still on Stock injectors but will be switching to ID850's soon. I'll look for the threads and read and learn...
  10. #90
    Feb 2018
    842
    So, how does one go about tuning this table for larger injectors?
  11. #91
    Jul 2019
    JAMESTOWN, ND
    54
    Quote Originally Posted by RobZL1 View Post
    So adjusting that eq to higher numbers, adds more fuel?
  12. #92
    Nov 2004
    St. Louis, MO
    476
    Made a quick histogram with Injector Tip Temp and used RPM and Cylinder Airmass to plot there is quite a difference in the AM vs PM. Note sure if that is what I should watch but time to read...
  13. #93
  14. #94
    Jul 2019
    JAMESTOWN, ND
    54
    I'd like to have that...
  15. #95
    Sep 2015
    Bozeman, MT
    701
    Original thread and all the work to get it done.
    https://forum.hptuners.com/showthrea...h-after-Flash/
  16. #96
    Nov 2004
    St. Louis, MO
    476
    Question I have is how can I be rich after flash when I haven't flashed anything? The only thing that changes is outside temp. I am not changing the tune. I'm just logging.
  17. #97
    Sep 2015
    Bozeman, MT
    701
    It is all covered in the threads. Rich after Flash is a condition caused by injector tip temp not being set correctly. Many other items it effects. Including correctly tuning a MAF.
