Results 1 to 9 of 9
Thread: Egr enable/disable button
    Did it get moved I can't find it anywhere
    Sep 2017
    736
    If using software version 4.4 your not gonna find it
    13,624
    Why would 4.4 make anything different?
    I still found it using 4.4.
    Just click edit, then navigator > exhaust folder. My EGR table was in there on a 2006 file I have.
    Sep 2017
    736
    My humbled apologies. That was a neat trick.
    They removed that fucnction from the main tables.
    HPT also admitted they are removing a lot of the emissions switches and noone could find it.
    I appreciate you bringing this up. Learn somthing new everyday
    Jun 2017
    Iowa
    61
    He knows all the neat tricks, because he is an alien from vega.
    Sep 2018
    213
    When did they say they were going to remove switchs??
    Thanks for the tip! I've never even looked looked in the navigator folder for anything like that
    Jan 2024
    3
    I know this is a bit old thread, but can you still disable egr with the new versions 5.1 on a Hemi?
    SoCal
    1,637
    Post your tune file
