Did it get moved I can't find it anywhere
If using software version 4.4 your not gonna find it
Why would 4.4 make anything different?
I still found it using 4.4.
Just click edit, then navigator > exhaust folder. My EGR table was in there on a 2006 file I have.
He knows all the neat tricks, because he is an alien from vega.
When did they say they were going to remove switchs??
Thanks for the tip! I've never even looked looked in the navigator folder for anything like that
I know this is a bit old thread, but can you still disable egr with the new versions 5.1 on a Hemi?
