Hey Guys,
So I'm reaching out to you in hopes to finding what the heck this car is doing.To start with,it is an 07 SRT8 charger that we did a 426 kit and an S-Trim Vortech system. Has a small cam, API 90mm T-body and ported heads/intake. Car drives great until you slow down below 30mph or when leaving from a stop/slow speed etc.
When you push the throttle past about 1/4 throttle only below 30mph its like the boost is forcing the blade open fully! Super scary. I've tried adjusting The throttle body airflow numbers up and down,DD tables,feedforward tables and some TM tables with no change in that reaction at all.It only changes the throttle pedal feel but still has that WOT blip.(as I call it) I've even stuck a new stock throttle body on it thinking it might be the API,same thing exactly. I've included the Tune and a log showing the blips,it does it three times in the log. Thanks in advance on this issue that's taking years off my life. I did a search and did a ton of reading but still have not found what it's doing. Thanks again
