Results 21 to 40 of 43
Thread: HOWTO: Ford Speedo Correction
    Nov 2016
    canada
    4
    can you sell me a tune for my mustang 2016 auto with 3.73 ??
    Jan 2017
    Does the speedo correction work on the 2014 f250 6.2l? I have tried everything you said to do but no luck.
    Tuner in Training HP_Mike's Avatar
    Jul 2017
    Mid East Coast
    12
    Quote Originally Posted by marcthebean View Post
    I am also finding this to be the case with my 2016 F-250. There is no "Use VID" parameter button in the speedometer calibration to be disabled, and no tire size modifications seem to make any difference.
    Advanced Tuner 15PSI's Avatar
    Feb 2016
    East Coast Somewhere
    458
    I don't think that Parameter is in your OSID. I think you have to use the Driven Tire Circumference parameter. Which Engine?
    2012 Mustang GT with S/C
    4Runner with S/C
    Turbo/NOS Hayabusa - 320RWHP
    Jul 2017
    Mid East Coast
    12
    Quote Originally Posted by 15PSI View Post
    My truck has the 6.2 gas engine, and the FX4 off-road package that came with 33.2" tall tires.
    The "Driven Tire Circ." value in the box was for a 31" diameter tire. That thew up a red flag in my mind that it was not the value being used by the odometer or speedo.
    I recently upgraded to a 34.25" tall tire and updated the "Driven Tire Circ." value accordingly. It made no difference as several people on this thread have complained about.
  6. #26
    Oct 2007
    Crawfordville, FL
    2,430
    Quote Originally Posted by HP_Mike View Post
    Please email your file to support so that we can investigate. We will get this resolved.
    Eric Brooks
    HP Tuners, LLC
  7. #27
    Sep 2017
    8
    Eric,
    Is this resolved? I have v3.6 and there is no Disable VID option therefore I can't correct the speedo.
  8. #28
    Apr 2018
    Has anybody resolved this issue? I have tried everything mentioned and nothing works. I have basically an endless amount of 2018 f250 and f150 to calibrate speedos on if hptuners can get the job done. If not it looks like hypertech will be getting the money
  9. #29
    Apr 2015
    south ga
    29
    I've got an 18 f150 I need to correct the speedometer on also. Any help?
  10. #30
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    Any changes on this? I have a 2017 F250 that I need to adjust the speedo on. Is the option in the VCM scanner like the Mustang/F150's?
    '17 Whipple'd S550
    Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
  11. #31
    Aug 2018
    Southern CA
    3
    so i have tried Calibration and Learn for BCM, but I can't seem to get my 305/35/20 tires to have the correct speedo. This is on a 2018 with a 10r80. I have even used a smaller circumference to no avail. Oddly, my drag wheels with the 305/45/17 have the correct mph when I put the tire circumference.
    My N/V base say 47, is that right?
  12. #32
    Aug 2018
    Southern CA
    3
    Anyone? Still having issues
  13. #33
    Nov 2009
    All Around
    3,149
    same here also no access through scanner for special function
  14. #34
    Mar 2016
    Texarkana, TX
    9
    I'm also having trouble with this issue. 2013 f350 with 6.2.
  15. #35
    Jun 2019
    18
    im having issues with a 2006 f250 and I even disabled the vid block and it still doesn't make a change. what is going on?
  16. #36
    I can use the scanner to change the speedometer(and gear ratio) on my 2018 F-150 XLT 5.0 but it won't work on my buddies 2019 F-150 Lariat 5.0. Both 4wd but I don't think that matters. Any idea why this could be? I'm running the latest version of beta.
  17. #37
    Apr 2018
    605
    Sooo how does one calibrate the front tires on an 11-14 copperhead pcm
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
  18. #38
    Jul 2019
    30
    2004 f150 here, went ahead and disabled the VID, changed the revs per mile to what they are for my tires (they're close to stock it was only like 15 RPM difference) and changed the axle from 373 to 355 according to the h9 axle code on my door sticker. Using torque Pro to see my GPS and OBD speed, below 50 those two and the speedo are all pretty much spot-on. Afterwards they start to decouple, GPS & OBD will be 2-4 miles apart while the speedo will be at least five above them, for example at 80 GPS speed the OBD says 82 and the speedometer is at 85. Any ideas on what's going on here? When I was just using the stock calculation with vid on it was only about two miles off at worst because the tires are only like an inch taller than stock.
  19. #39
    Dec 2017
    767
    will this work on 2020 ford ranger?
  20. #40
    May 2020
    Quote Originally Posted by Bill88stang View Post
    I just adjusted my 2020 Ranger using VCM Scanner tool. I have only done a short drive on the freeway at various MPH -- seems to match my GPS mph. If I have any trouble I will report back.
