redownload it lol the file should be ~23.5mb in size...make sure its no smaller then that basically. Im sure their servers are getting their asses kicked right about now though.Originally Posted by bestes125
hi all
i guess this question is for the moderators? just downloaded 2.1.14. looks great. i have noticed that in my editor for my ls1 that there are simpler parameters in my sd operating system. question am i going to have to do a write entire since the format changed, or when i do my next write cal, will the changes go into effect? thanks again for the great product and awesome up grade
2000 Transam- SLP Lid, K&N Filter, SLP Air Induction Kit, TB Bypass, Ported TB, Stock MAF, All Free Mods, 160 T-Stat, Pacesetter Long Tubes, TSP Catted Y-Pipe, SLP Loudmouth 2 Catback, HP Tuners, UMI Performance Suspension Stuff
No need for write entire. The file structure and layout has changed. When you save your file, it will be saved with the new file structure.
EC
Always Support Our Troops!
Duh! Knew I didn't click on everything, lol!Originally Posted by foff667
2002 BSM T/A WS6 #3371 (Sept 12, 2002) "LOB"
TSP Tqr II (232/234 113lsa +2), ETP Heads, FAST 90/NW 90, 42#SVO, 25% Powerbond Pulley, FLP catted LT's, B&B Tri-Flo, QTEC, Smooth bellows, Fast Toys 85mm lid & Grn Filter, Lou's SS, LG SFC's + X Braces, LG LCA's, LG PHB, LG DSSL, LG TA, Koni SA's lowered, Z06 Front brakes, Earl's SS lines, IForged Classics (18x9.5" F, 18x10.5" R) & very big and expensive stereo... (Eclipse, Zapco, Focal, Lotus)
thanks EC_Tune. i just love this, much more simple for me now. to bad i am going to put my car away at the end of the month lol . thanks for the quick reply.
eric
So whats going to be under the new SD TAB? he he ........
The new trans layout is WAY better. Nice work!
2000 EC, SB Z71 03 LQ4, 05 front clip with e-fans, STS turbo, GT67, Blow off valve, 170Kpa, Alkycontrol, 44lbs injectors @ 100% dutycycle, Comp 918's, HPtuner, 02 ECM, Dyno Jet Wideband, Eaton LSD, Speed Engineering 4l80e conversion, 2800 ART CARR stall removed now running stocker . 11.87 @ 114
New times 11.41 @ 119.. look out 10's here I come.....
SD for the 2006 E38 ECM's...
Got it, thanks guys!
Black Pontiac Trans Am WS.7- Runs on E85
And soon to be powered by Twin Turbos.
How to run your LS1 on E85
Still only for gm.....
30th anniv. TransAm
Bullitt Mustang
Ram 2500 cummins 6.7
2009 rx8 r3
Originally Posted by mulot30th
I second that question???
-yesOriginally Posted by mulot30th
And not for LS2's..
05 GTO
403ci LS2
Dart CNC 225's
TH400 - Chance converter
10.75 @ 124mph na
9.76 @ 141 on the spray
[Grumble]*grumble grumble* still no Ion 2.2L ecotec *grumble grumble*[/Grumble]
No RTT for a 2002 LS6 yet either then?
Should be. You can find out in the editor, just open up your file and go to the Operating System form.
We got this guy Not Sure, ...
Nope, it says '2-bar MAP - Speed Density', but no (RTT) beside it...If you are the owner of HP Tuners, is there a chance you can check to see if there is indeed no RTT for a 2002 LS6 (z06), or if I'm just doing something wrong? I would sincerely appreciate it. Thank you sir.Originally Posted by Keith@HPTuners
fwiw im looking at an 02 Zo6 file right now...OS #12221588 & RTT is enabled for 1/2/3 bar SD & 1 bar maf post your file if you don't mind, but it should be there. If not be sure your updated to version 2.1.14
Its all based on operating system, not vehicle year/model.
yeah i know its also possible that he somehow didnt install .14 though...just covering all bases which is why I asked for him to post the file so we could see.Originally Posted by Keith@HPTuners
