I am tuning an LFX V6 but still tunes like a Gen V.
While doing WOT pulls from 2K-5K, the throttle is not fully opening below 4K indicating the engine is outputting more torque than the MAX Torque value says it should.
Looking at the Virtual Torque Table, it says I should see Torque in the 280-290 ft-lb range, but the MAX Torque PID is registering around 215 ft-lb. The lower value leads to the throttle being closed down from WOT. I upped the Peak Torque Table to eliminate that potential source and it now appears the MAX Torque value is the culprit.
Looking at the other entries in the Max Torque section I find optioned out of consideration, either by disabling or entering a value greater than it will ever see.
Can someone explain how the MAX Torque value is reduced some 27% from the Virtual Torque Table value?
