Maybe this thread will stop a rush of questions to support.
In the JTEC controllers, there are a lot of "units" missing when you right click. Are these going to be filled in?
The cold warmup tables are listed as coefficients - are these simple multipliers - like percent - or are they pulse width adders or what? Are the map and time based tables additive?
Same question about the PE table. Adders, FAR, pulse width, multipliers or what?
Is the injector scaling "hard coded" as far as the math is concerned IF the PE table is FAR? Otherwise how would it know how much pulse width to command if it didn't know how much flow vs pulse width?
Lastly, is there a way to turn off or re-scale the barometer update/learn when using a 2 bar map?
