Results 1 to 2 of 2
Thread: Do Eqiuvalence Ratio Commanded work on Spanish oak WB and AFR Error vs Maf
    May 2018
    Germany
    623
    Hey,
    Ive read about an issue with the Equi Ratio Com on 05 Mustangs 3V.
    I want to log AFR Error vs Maf Volts.
    Can I do this or shows the Eqiu the corrected Y, not the commaded ?
    yes but in your channels list, right click on mpvi2.1 ngk afx, click transform, under equivalence ratio, click ngk afx. this converts the ngk afr to lambda. only way you can plot ngk against maf voltage on the spanish oak without building something custom
