Results 1 to 20 of 40
Thread: Anyone have a base tune for a LQ4 with a 224/230 .550 cam/ 48lb injectors???
    Sep 2019
    Cincinnati, OH
    29
    I am seeing if something in my tune will not let it idle... Its got a 3000 stall converter. I am a novice to HP tuners and self tuning... someone please help.
    13,615
    Post your current tune and logs.
    Provide more details about the engine setup. Like what injectors are they, brand.
    Are you running a MAF still?
    How is fuel pressure at the rail??
    Sep 2019
    Cincinnati, OH
    29
    stock rebuild lq4 with btr stage 4 truck cam (gen 1) LS1 intake shorty headers, cats removed, rear 02s removed, stock 4l60e with 3000 stall and corvette servos. planning on running Nitrous.
    58lbs at rail, 48lb/hr SVO green tops, and new fuel filter.
    Sep 2019
    Cincinnati, OH
    29
    cant figure out how to post my tune and logs....
    Sep 2019
    Cincinnati, OH
    29
    I also just upgraded the fuel pump to a 340lph quantum
    13,615
    Use the advanced reply, from there you can add attachments.
    Sep 2019
    Cincinnati, OH
    29
    5fdp
    I am trying to do away with the MAF as I know this an aggressive cam (111 LSA) I am smelling a whole lot of fuel on cranking... TBH Ive never been more lost and feel dumb AF.
    May 2019
    new england
    74
    if your gonna do away with maf. you need to set dtc to mil on 1st error. adjust your fuel>flow rate vs kpa to your new injector data.
    also a note when you get it running and start adjusting fueling you are gonna have to make changes to the secondary ve table then copy to main and interpolate. between every other row.
    Sep 2019
    Cincinnati, OH
    29
    Should I adjust lower or higher based on the bigger injectors?
    13,615
    Sit back and think about what you just asked lol.
    If you put in larger injectors, the number is of course going to be larger than it was before. If those injectors did not come with injector data for you to plug into the tune, you better find it because you'll be kinda lost without it. Or just sell them and get better injectors with known good data. Everything from injector flow rate, offset vs volts, short pulse adder, minimum injector pulse all have to be changed for the injectors. This is where data is key.
    As said, you will have to set the MAF dtc's to MIL on first error for speed density. And you will have to understand how the stock operating system works in speed density with the primary and secondary VE tables.
    Or you can upgrade the OS to the 2 bar OS upgrade in the OS tab, this would remove the secondary VE and give you a new primary VE with more cells that go all the way to 210kpa instead of 105kpa. This engine wouldn't use the portion above 105kpa but that doesn't matter because the stock VE can still be pasted back into the 0-105kpa section and worked on from there.
    Sep 2019
    Cincinnati, OH
    29
    Thank you. These are some bullshit Amazon injectors... I swapped back in the LS1 stockers. I knew better, I should have just got some Deatschwerks. Do you think the stock LS 1 will support it until I can get the better ones?
    Sep 2019
    Cincinnati, OH
    29
    I've been building restomods and full restos for about 15 years. I had no idea tuning was this complicated. I just want to get it running so I can limp it to a tuner
    13,615
    Yes, the stock injector will get you by if you just need to get it running. They just aren't going to be large enough once you got to full throttle tuning.
    Sep 2019
    Cincinnati, OH
    29
    Quantity: 8 Fuel Injectors
    Condition: 100% BRAND NEW
    Design: Bosch GEN III EV1 Style Fuel Injector
    O-Rings Included: Yes, preinstalled
    Injector Design: Metal & composite plastic
    Nozzle Design: 1 hole disc
    Connector Type: EV1
    Filter Design: Basket filter design at inlet
    Spray Pattern: 15 Degree Spray Cone
    Specification
    Coil Resistance: 12 Ohms / High Impedance
    Static Flow Rate: 42 lb/hr = 440 cc/min @ 43.5PSI ( 300kPa )
    Gain: 0.12ms/MG
    Offset: 0.055ms
    Turn on time @ 14VDC: 1.14ms
    Turn off time: 0.85ms @ 300KPa
    Amperage: 1.0 Amps
    Pressure: Min 30PSIG/ Max 100PSIG
    Length: 3" (74mm)
    O-Ring Diameter: 14.5mm
    Sep 2019
    Cincinnati, OH
    29
    So I guess Amazon didnt let me down that bad...
    13,615
    That information is good an all but if there is no spreadsheet with the tables I talked about previously, they are kinda useless.
    Dec 2008
    Nevada
    4,452
    i would have got the injectors from a company like FIC who supplies the gm specific data to match their injectors.
    Sep 2019
    Cincinnati, OH
    29
    I concur... any recommendations... So I swapped out my 42lbs to the stock ls1... still not getting any injector pulse. I can command the injectors on with 60lbs at the rail... and it will start for about 10 seconds. I have no injector pulse even though the VATS is disabled. I am so beyond lost.
    Sep 2019
    Cincinnati, OH
    29
    Bad PCM?
    13,615
    Not a PCM problem.
    It's going to be calibration related. Post the most recent tune file with the changes you've made.
