Results 1 to 14 of 14
Thread: OBD 1 diagnostics, what do you guys use?
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    I have a 95 Grand Am as a DD. My check engine light came on and Advance Auto lost their stuff to read it (go figure) so I figured I would see what I can get to have my own scanner. I just care to read codes.
    What do you guys use for obd 1 diagnostic check? If its not fairly inexpensive, dont post lol I dont want to spend a lot, but if I can get something cheap, it would be nice to have.
    Mike
    Sulski Performance Tuning
    Tuner 1slowsilverado's Avatar
    Oct 2005
    Daytona Beach
    104
    I own an OTC its a 3K paper clip as far as im concerned. In fact I use a paper clip to pull the codes and only use the otc if I need more.
    Jan 2005
    Concord, NC
    8,093
    Otc?
    Oct 2005
    Daytona Beach
    104
    yea otc makes it, Its called a genisys
    28,320
    Oct 2005
    Daytona Beach
    104
    If you just need the codes... Jump A&B with a paper clip. (Top right last two are a/b) Then turn the Key on Engine off and count the flashes.
    Jan 2005
    Concord, NC
    8,093
    ok thanks guys
    Jul 2004
    1,579
    OTC = Over the Counter.
    Jan 2005
    Concord, NC
    8,093
    definaltly didnt work lol, I only have one on the top right and then 2 pins right below it.
    Oct 2005
    Daytona Beach
    104
    Do you have a 12 or 16 pin DLC?
    Jan 2005
    Concord, NC
    8,093
    12 pin
    Oct 2005
    Daytona Beach
    104
    Ok the 16 Pin OBDI Needs a scan tool, The 12 Pin DLC doesnt. I can only assume that its mounted upsidedown. Should be...
    FExxBA
    GxxxLM
    (A) ground
    (B) Diagnosic terminal
    (E) Serial Data
    (G) Keyless entry
    (F) Tcc
    (M) Serial Data
    (L) Serial Data
    You may not have all the pins above. Just jump the two pins next to each other. If its the wrong pins no worries, It wont fry anything like OBDII
    Jan 2005
    Concord, NC
    8,093
    mine is like this
    xxxxx1
    xxxx11
    one denoting a pin, the top right is a black wire, which I assume to be ground. If it was mounted any other way, it would look like your FEG part of your post. I only have 3 pins in the connector.
    Jan 2005
    Concord, NC
    8,093
    I will have to look at another one and see if its the same...
