so have a question to tune 2019 coyote is it possible with mpvi1 ?
No, you need the mpvi2 and you need Internet as well.
ok sounds good thanks @Bill88stang
I wonder why the internet is needed. Something to do with unlocking? If Ford is going in the direction of making cars complicated to tune I will never buy a 2018+
Knock Retard is the reduction or prevention of knock by lowering ignition timing:
(+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
(--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
__________________________________________________ ________
2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
Don't fix it if it ain't broken | Maximum effort gets maximum results
Virtual read?
v-performance.pl/
facebook.com/veee.performance/
https://www.instagram.com/v.performance.pl/
Remote tuning:
[email protected]
+48 697276579
I helped a buddy tune his 19 with an mpvi1.
Internet is needed for Seed Key Combinations. They are stored on the server instead of built into the software. This was done to prevent software reverse engineering.
