Results 1 to 12 of 12
Thread: L83 MAP sensor to L99 3 bar
    15
    I have a 2018 L83 with a Whipple 2.9 and installed a GM 3 bar MAP intended for an '18 L99.
    What parameters need updated to instruct the ECU that it now has a 3 bar?
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,018
    airflow-general-characteristics
    linear and offsets need to corrected to new map sensor
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    15
    Thank you mbray01 Sir.
    Where do I find the info to update the values?
    13,599
    The google.
    The part number is likely the red GM 3 bar map. If that is what it is, the settings should be 312.5 and -11.25. I forget the part number off hand.
    Dec 2013
    Slidell, La.
    1,018
    pull one from a file that used that sensor, ie the stock vehicle file from the repository
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    15
    Thank you 5FDP and mbray01. I have been ALL over google and have found a variety of values; I also noticed the same part number is used on both the L83 and the L99. Why would the pn be the same and each require different values?
    13,599
    What part number did you buy?
    This is the GM part number for the red 3 bar GM map that I always use.
    # 12592525
    15
    5FDP, I ordered 12644228 after researching Pace Performance and rock auto for part numbers I installed it today and the truck runs but is pig rich! That was the only change I made.
    15
    mbray01 I dug around in the repository with no luck. tried a few different models that use this MAP part number.
    13,599
    This site says it's a 1 bar sensor.
    https://paceperformance.com/i-134792...4-engines.html
    15
    5FDP I discovered the same thing. I know Whipple suggests using the stock sensor and I have been following threads on this forum and decided to try 3 bar. I will order the 2525 tomorrow.
    BTW, will it plug into a three-pin connector?
    Install the 12592525 red 3 bar map sensor. It fits directly and the data:-
    linear= 312.5
    offset = - 11.25
