Need heip with tuning the turbo for exhaust brake
What do you want to know the lower the # in negative -37 the stronger the brake. -47 is more
Hi Jeffrey i was told the turbo on a 550 is different than a pickup what table do i go into Thanks
It?s under (Torque Managment) (Driver Demand)(TurboCharger) (exhaust brake)
Ok i will try and adjust it this week Thanks Again for your help
Well got a chance to check it out today looking like my table is marked all -74 across the board in every box what rpm should i mess with ?
go from -74 to -150 across the whole table then go to -250 at the higher RPM and smooth it down to the -150 at the lower RPM. The bigger the negative number the more engine braking effect up until the turbo vane is closed all the way at which you won't notice any more of a braking effect. Play with it and see what you like. Exhaust brake.PNG
Thank you very much i will play around, see what it can do. Thanks again now to get the trany unlocked i have to send a file to hp to open it for me
Wow what a difference I was under doing it by using stock configuration Jagerwrenching is the man
Jagerwrenching i was told that my turbo on my 2011 6.7 F550 is different. Ford put another style of turbo on the 450 / 550 will this still work it does not have vanes its wastegate style i believe
It does not work to good on a waste gate turbo did not feel any hold back even using the tow hall button . i do not have a button to push for exhaust brake
Thank you very much for the help
