ve 2.3.hpl
VE CL 2.3 with updated ve still limp mode.hpt
08 ls3 vette with 6l90 is wanting to takeoff from 4th gear when tuning ve. I have attached the file and log if anyone sees anything to help me out with this problem.
Thanks!
ve 2.3.hpl
Thanks!
I have had this in the past, i forget exactly what caused it, I do know it is in the ecm torque management tab that it is happening. I would go back to a file that is known good, then load your settings back one at a time, till you hit it. Its cumbersome, but its easy to tell if its fixed or not, if your logging commanded gear, it shows 4 as soon as placed in drive
Michael Bray
Rusty Knuckle Garage
Slidell, Louisiana
20yr Master Tech.
Advanced Level Specialist
GM World Class Technician
Shop Owner
This worked! Needed around with some torque mgmt settings and set P0101 to no error reported. Not sure which one did it but I can now start in first gear!
