Page 6 of 6 FirstFirst ... 23456
Results 101 to 110 of 110
Thread: SD tuning for E38/E67 ECM's
  1. #101
    Jun 2010
    Fort Walton Beach, FL
    7
    Get the custom OS for your E38 and don't look back. I simply use Bluecat's tool now to quickly look at actual VE numbers since it can quickly bake out the cylinder volume * R gas constant out.
  2. #102
    Tuner iced98lx's Avatar
    Jul 2008
    Sioux Falls, SD
    58
    Anyone seen any walk throughs of using the new tools in 3.0+ for SD Tuning e38s or are the BlueCat walk throughs accurate.
  3. #103
    Jul 2008
    Sioux Falls, SD
    58
    Quote Originally Posted by iced98lx View Post
    I suppose this is sort of a silly question as I could follow any walk through for regular VE Tables and the VVE table should work generally the same.
  4. #104
    I have no idea how to use the vve editor. is there a guide?
    This is really beginning to piss me off. I miss the old "411"ecm.
  5. #105
    13,624
    https://forum.hptuners.com/showthrea...tarted-Threads
    Try that.
    Setting up the VVE is like tuning a regular VE table. You are just using different tables and values is all. It's is more complex with some of the fuel trims parts or the rich/lean after flash stuff but you can still get it down.
  6. #106
    Is there a way to use the compare function to compare old and new VVE portions of the tune? At this time when I'm looking at a VVE table I can't look at anything else until I close that window.
  7. #107
    Oct 2010
    213
    Quote Originally Posted by ericwilloughby View Post
    Not that I'm aware of. I have printed out the original, then print out the new and eye ball it. It gave me a head ache so I stopped. There should be someway to put old and new into a spread sheet and do a compare there.
    Try this. https://www.ablebits.com/office-addi...-files-sheets/
  8. #108
    Quote Originally Posted by sprinto7 View Post
    Thanks for the reply. I never figured out a way to compare. Took a while to learn to tune vve. I found it much easier once I learned to use the correct manifold switch option and zeroed out the other 3 so I wouldn't accidentally find my way back into the wrong vve table.
  9. #109
    Australia
    2,004
    u can open the editor twice so u can then look at and copy/paste from one to the other
  10. #110
    Holy cow. I?ve been tuning a whole lot of ecotecs on e67s and I got curious about tuning them speed density (as I do with a lot of LS stuff and obviously stuff on p11s and other speed density only ECMs) and WOW my head is spinning. I should?ve paid more attention in math class.
